Hi Everyone,
I think this is a super easy task, but I am not sure if I am missing something or not. I am hoping that one of you GeoNet geniuses can help me make sure I am doing this correctly. I am creating a TIN for a project. Here is the exact wording of the request:
Provide an integrated bare earth surface model that combines both aerial LiDAR data and ground-based survey data, including survey points from the submerged stream channel (as applicable), in ESRI triangulated irregular network (TIN) format. |
Now, I see my .las data (in which I am able to create an LAS Dataset and then convert it to a TIN), and I see some survey points as well. Though, I don't understand how I am to supposed to include both of these data and make a TIN out of it. The LAS Dataset To TIN—Help | ArcGIS for Desktop tool that I am using only asks for the LAS data.
Would it be safe to assume the the LAS Data already has the ground-based survey control points integrated into it (since the LAS data does have elevation and classification)? Or am I completely missing something here?
Please help and thanks!
Oh, I am using ArcGIS Pro 1.2 but also am using ArcMap 10.3.1 - either way, it does not matter (I don't think). I also have 3D Analyst. Managing Data Federal Esri Surveying GIS for Hydrographic Surveying Land Use / Land Cover / Forest Cover Mapping
