Contour line to DEM
28287
12
09-15-2011 08:05 AM
by Anonymous User
Not applicable
Original User: luke.kaim
I have an elevation dataset that is contour lines (lines). I have already made a TIN using this data, but for the life of me I can not figure out what arc toolbox command to use to create a DEM from the TIN. What arc toolbox command do I use to do this? I know I can go from a DEM to a TIN. I now want to go the other way. I have a student license of arcgis so I have all the extensions. Ideally I want to go from contour lines directly to a DEM. Is this possible?
Thank you,
Luke Kaim
Thank you
Luke Kaim (SIE)
Lucas.Kaim@maine.edu
(914)263-7866
Tags (1)
by Anonymous User
Not applicable
Original User: stevelynch
Jay
- Where are you sending your output?
- Try writing it to Esri grid in a newly created folder.
- Try running the tool in foreground mode (Geoprocessing->Geoprocessing Options->Disable Background processing)
Steve
anitaYeeting
I am still having problems displaying my outputs.
I have tried to disable the background processing and I still dont get my outputs displayed on my map.
My outputs are send to my workspace...the output was generated and added to the table of content but it was not displayed on the map.
What do you mean by writing it to ESRI GRID?how to do that???
Jay
myname
first you create tin from contours
then you convert tin to raster/dem
here clip for you Coutours to DEM in ArcGIS - YouTube
