BIM 360 and ArcGIS integrations
2345
7
07-11-2021 05:12 AM
RoddasCabral
Hi there, I would like to know if there is some way to integrate BIM 360 and ArcGIS project just using the ArcGIS API's .
DA_BIM-GIS
Hello
There are no public APIs in ArcGIS Pro for working with BIM360.
DA_BIM-GIS
Hello
RoddasCabral
So if I wanted to do this using code, how would I do it? Or using code is not possible?
AduriSreenivas
Hi there,
Using BIM 360 REST APIs,  can we integrate with ArcGIS Experience Builder REST web services ( using Web scenes)?
DA_BIM-GIS
Hello,
yes, but you need to have a way to link the digital model to the scene . What are you trying to do (Just general idea).
Best regards,
David
AduriSreenivas
Hi David,
Thank you. ..  Yes, I have BIM/ Revit model.
I will be using ASP.Net for Autodesk BIM 360 web viewer application using Autodesk Forge BIM 360 API.
I have converted BIM i.e. (Revit model) to Web scene.  And using (Experience Builder) ArcGIS REST API… I want to link Web scene to BIM/ Revit model.
Finally, I am looking " in the same browser” to view the Web scene and BIM/Revit model.
I have attached the screen here.  I find this screen from the below link..
https://www.esri.com/about/newsroom/arcuser/gis-and-bim-integration-leads-to-smart-communities/
Is it possible for the my above mention requirement and solution?
Than you.
Aduri Sreenivas
DA_BIM-GIS
Hello Aduri
you can do that, also you can look into GeoBIM (https://www.esri.com/en-us/arcgis/products/arcgis-geobim/overview) as another possibility.
David
AduriSreenivas
Hello David,
Thank you.
Yes.. I did ArcGIS GeoBIM application and I have attached the screen here.  We can show in one browser web scene and revit models for AEC industry development solutions.
I also attached another screen a (Prototype) for an Integration of ArcGIS Online and Autodesk BIM 360 web viewer.   As I plan to develop a prototype " Building Permit System " using Autodesk Forge API integration with ArcGIS Rest API.
  • Upload BIM Models in a web browser
  • IFC checker: Validate the building code rules)
  • Building permit reports
  • GIS viewer for Urban views
  • Project Schedule Dashboard
Therefore, I conclude that we can link the digital model i.e ( revit model) to the web scene.
Thank you again,
Aduri Sreenivas
