Do you have return numbers, class codes, intensity values, etc., that you need access to? What do you intend to do with your lidar data? Going to LAS may not be your best option.
You might try the txt2las utility from LasTools: http://www.cs.unc.edu/~isenburg/lastools/
There are several websites that provide LAS files. I have tested ArcScene 10.1 beta with some of the LAS files located at http://liblas.org/samples/. LAS file "2398_400.las" contains RGB values. Alternatively, you could use software to convert your text files to LAS. I have installed LP360 (30 day evaluation) and it can convert text files (like PTS) to LAS. Make sure to choose LAS version 1.2 in LP360 to enable RGB.Good luck!
I downloaded the file to experiment with. I seem to be unable to load *.las (v1.2) in ArcScene (and toolboxes). Could you tell me how to do this?
Hi Luc,You have to create a LAS dataset with the new "Create LAS Dataset" tool. You'll find this in 3D Analyst Tools / Data Management / LAS Dataset (or just do a search for "LAS Dataset"). You are not able to add LAS files to ArcMap or ArcScene directly, but after you create the LAS Dataset you're good to go.You may also be interested in this Esri video where native support for Lidar is explained by Nathan Shephard:http://video.esri.com/watch/454/native-support-for-lidarGood luck!Kind regards,
I got LiDAR-data from a guy that said it was ascii. file-format says .cenz. Anybody heard of .cenz? when i open the file in texteditor: Class x y z
How can i make a pointcloud out of this?
regards,
Anton
The suggestions mentioned above (using LAStools to convert the ASCII data to LAS) are still valid. Have you tried that?
And if you download LasTools these days, it comes with a bunch of Arc style Toolbox tools.
Very good tool set.
If i try txt2las it says invalid filetype. I manage to make shape-points of it by adding the data into excel and then export as csv and the create points from XY. Then i tried to run shp2las but always when i try to use LasTools i get error. Could that be a licence issue?
/ Anton
The toolset is free as far as i know.
Are the files still names *.cenz?
Try changing the extension to txt
I did try and still got error using txt2las. I will redownload LasTools and try again. I did also try using FME xyz point cloud -> LAS did go through but nothing showing.
It´s also very big amounts of data so i did try everything with just a few points. Didn´t work.
I did try the new update of LasTools and i didn't work. As you can see above i have 4 columns: Class x y z. Could that be the problem? when i try FME the program only reads the first 3 columns and it doesn't work. I have lots of rows so it's not possible to import in excel an delete the first column either. Any ideas what i could try next? I have also tried to make a shapefile with points and then transform to LAS in FME, didn't work. In txt2Las i tried to change the phrase string to cxyz, c=classification.
The files i got was in an unknown format to me, .cenz. How did you mean i should make it a .txt instead? I did copy the data in to a txt-file. Maybe that's a problem?
Thanks for your time,
This is the error i get with LasTools.
That's not much information... Would it be possible to share (a small part) of the information?
it worked one time.
I didn't know i could make the error window bigger, when i did it said error: no input
Then i tried change file-"format" in the input window. (see picture)
Then I managed to run it successfully twice but then the same problem appeared.
EDIT: It seems like it's necessary to have the input-file on the same drive as ArcGIS
So you made it work. I'm glad you could fix it!
Yes, Thank you.
I think that the problem was just that i have two drives on my laptop. The input file needs to be on the same drive as ArcGIS. The parse string i used for my ascii file (see above) was cxzy. It worked fine.
Thanks for all support,
@ClaytonCrawford we still need to convert TXT to LAS, any chance this could be prioritized with Pro 2.9. If so we can finally lay ArcMap to rest?
I don't think we every had a supported tool in ArcMap to do that conversion. A sample utility perhaps. We don't get many requests for this so it's hard to justify prioritizing a new tool for it in 2.9. Would a command line exe callable from a script based GP too suffice?
Hi Clayton.
Basically, I'm asking to have ASCII Text To LAS from 3D Sample Tools implemented in Pro ;o)
LAZ to zLAS and zLAS to LAZ are already part of Convert LAS so I was hoping that ASCII Text To LAS could be implemented in Conversion Tools/LAS?
Regards, Klaus
Signed in members can post, follow updates, and more. New here? Register a free account.
