Kevin:
I have not experienced a problem using the tool with 10.3.1 since I updated the file. I tried the tool just now in response to your post and the dockable window opened fine, recognized layers with M values fine and performed an update fine. To be sure I attached the correct add-in file I have deleted and reposted the add-in to my post above with a new date time of 12/13/16 at 12:17 PM.
Do you have any other extensions running, especially editor extensions? My system has Attribute Assistant installed and that did not cause any issue for my tool, but other editor extensions might.
Be sure to uninstall any prior version of the Add-In before installing the new one. Anyway, please relate the installation process you used if your problem persists. Also open Task Manager and report any unusual memory use or performance behaviors shown during the time the application crashes.
Thanks Richard. I have enjoyed the addin over the last year+ in our 10.1 environment.
Hi Richard,
I am running 10.3.1 and every time I click on the icon to open the tool my arcmap crashes. Have you experienced this before? Any suggestions?
-Kevin
The addin attached to this reply as been built to work with ArcMap 10.3. I have left the attachment to the original post as the version compiled to work with ArcMap versions 10.0 to 10.2. If you have found this addin useful let me know or give this post a like.
Is has this been updated for 10.3?
Thank you very much for your answer. Yes, I need to upgrade my ArcGIS!
There probably could be a 10.0 version if I was able to compile it on a machine with ArcGIS 10.0 installed, However, no one has that version where I work now, and I don't have administrator rights to install it myself. I don't have a good case to ask IT to install if for me that relates to my work.
If you can upgrade to 10.1 or 10.2 I think it is very much worth it. Either of those versions is much more stable and has much better performance than 10.0.
Thanks for sharing this useful tool!
I have a question, there is a version for ArcGIS 10.0?
Regards,
Gastón.
If you have downloaded the Add-In contained in this thread and used it let me know if it successfully listed your Route features and updated the 3D measures or if you had any problems getting it to work.
