3D Analyst - Line of Sight/Interpolate Lines
8515
05-24-2010 09:38 AM
deniseklein
Hi there, I used the Line of Sight and Interpolate Lines tool in the 3D Analyst, which worked great but has left a line on the map that shows visible and not visible points.  Is there some way to delete this line?  I have a few because I was trying to figure out the tools so the map looks messy.
ModyBuchbinder
Hey
This is just a graphics. You can select and delete it just like any other graphics using the Select Element tool in the drowing toolbar.
Have Fun
Mody
ShahriyarIsmayilov
I would like add
if there were any problem, you cannot delete that, do stop editing if you start it on Editor toolbar before "using the Select Element tool in the Drawing toolbar"
Shahriyar
