2D Marker not visible through 3D Object (Indoor, behind 3D Object ..)
1344
02-27-2023 04:59 AM
ChristophHaeberli
2D Layer Features, symbolisced as 2D Marker, Relative to ground or relative to scene, are not showed when they are inside or behind a 3D-Object (Scene Service, like a Building).
Tranparency on the 3D-Object makes no difference, exept 100%.
Workaround: 2D Layer as Style 3D-Object
Any plans, that the 2D Symbols are also showing up, if behind 3D Objects? This is important for indoor sensors, Beacons, Analytic-Points (Noise, Visibility and more)
Tags (3)
GreteSoosalu
Hi @ChristophHaeberli
This is in our backlog but not yet planned for a release.
Thank you for sharing the use cases, this helps us to prioritize the backlog!
