Minor update to the Survey123 website and web app
1434
02-12-2020 08:24 PM
IsmaelChivite
Esri Notable Contributor
6 0 1,434
We recently applied a minor patch to the Survey123 website, web app and report service. This is a very focused update addressing five issues recently reported.
  1. BUG-000128390 Surveys created and accessed through the Survey123 for ArcGIS website returns the error message, "Survey does not exist or is not accessible" when special characters exist in question or choice labels. Thanks to Jeff Carney and‌ Kanin Sangcharoenvanakul‌ for their Survey 123 web Form Error discussion.
  2. BUG-000128110 A geopoint question added from Survey123 web designer will not render correctly in the Survey123 field app.
  3. Surveys published from Survey123 Connect after January 21 do not render DateTime questions correctly in the Survey123 web app. Thanks to Jônatas Lima Póvoas‌ for reporting the problem.
  4. Surveys published to ArcGIS Enterprise cause the Survey123 Report service to fail if "Include default maps" is enabled in through the Maps settings in Survey123 Connect. Thanks to Kanchana Karthikeyan‌ for reporting this issue.
  5. Surveys published from Survey123 Connect will cause the Survey123 Report service to fail if the target feature layer is missing Editor Tracking fields. Thanks Mervyn Lotter‌ for reporting and helping out with the diagnosis and validation.
For fixes to issues #2 and #3 to take effect, you will need to re-publish your survey.
We have also made available in the Early Adopter Community | Esri Early Adopter Program new updates to version 3.9 via the latest Survey123 3.9 RC builds. 3.9 is scheduled for release in April. We are targeting the inclusion of new features including:
  • Survey update notifications in the field app.
  • Replacement of the Geopoint question type with a new Map question type with support for point, line and polygons.
  • Expanded Survey123 report syntax: Statistics and summary tables.
Check the Early Adopter Community announcements for details.
Tags (3)
