Critical Update to Survey123 available (1.10.25)
5547
14
01-12-2017 11:18 AM
IsmaelChivite
Esri Notable Contributor
8 14 5,547
A critical update to the Survey123 field app is now available to address the following issues:
  • BUG-000101764: This bug prevents version 1.10.23 of the Survey123 field app from submitting data to surveys published to Portal for ArcGIS if the survey had no repeats.
  • BUG-000102016: This bug prevents version 1.10.23 of the Survey123 field app from submitting data to surveys with repeats published with Survey123 Connect 1.9 and prior.
Thanks to all of you that took the time to report the issues via GeoNet and Esri Tech Support, help us narrow down the problems and even test the fixes.
This update increases the build number of the Survey123 field app to 1.10.25 and is available across the following platforms:
 Survey123 Connect for ArcGIS and the Survey123 web site are not affected by this update.
 The source code of Survey123 for ArcGIS included with Appstudio for ArcGIS has been updated to match 1.10.25 and  made available.
14 Comments
