The infinite monkey theorem states that a monkey hitting keys at random on a typewriter keyboard for an infinite amount of time will almost surely type a given text, such as the complete works of William Shakespeare.
You don't have an infinite amount of time to write your survey and hopefully your keystrokes will be less random than that of a monkey, so the time it will take you should be significantly less than infinity.
We have provided many resources to help you write your survey: blogs, samples, templates and documentation. Identifying which of these suits which users is as a challenge. Saying something is easy or difficult, alienates as many people as it helps.
Borrowing from (and bending) the infinite monkey theorem, we have chosen a classification scale to describe our content. If the goal is a survey (rather than the complete works of Shakespeare), and you have a computer and some sustenance - in this case bananas - you can build your survey. The question is how many bananas?
Every monkey needs to eat, and depending on how difficult / complex / time consuming a task is, more sustenance is required. Here is our banana rating for our Survey123 resources:
Right now you can see the banana rating in the Samples that are available in Survey123 Connect.
New blogs will also use the banana rating to help convey the difficulty, complexity and time to digest for the content.
