import arcpy
import pythonaddins
from arcpy import edit as EDIT
class Btn(object):
"""Implementation for Python_Snaptool_addin.button (Button)"""
def __init__(self):
self.enabled = True
self.checked = False
def onClick(self):
pass
class Edit_Operations(object):
"""Implementation for Python_Snaptool_addin.extension20 (Extension)"""
def __init__(self):
# For performance considerations, please remove all unused methods in this class.
self.enabled = True
#edit = arcpy.da.Editor(r'D:\Sample.gdb')
#self.onStartEditing()
def startup(self):
pass
def onStartEditing(self):
pythonaddins.MessageBox('Select a data frame', 'INFO', 0)
pass
def onStopEditing(self, save_changes):
pass
def onStartOperation(self):
pass
def beforeStopOperation(self):
pass
def onStopOperation(self):
pass
def onSaveEdits(self):
pass
def onCreateFeature(self):
pass
class LineClass(object):
"""Implementation for Python_Snaptool_addin.tool (Tool)"""
def __init__(self):
self.enabled = True
self.shape = "Line" # Can set to "Line", "Circle" or "Rectangle" for interactive shape drawing and to activate the onLine/Polygon/Circle event sinks.
def onMouseDown(self, x, y, button, shift):
pass
def onMouseDownMap(self, x, y, button, shift):
pass
def onMouseUp(self, x, y, button, shift):
pass
def onMouseUpMap(self, x, y, button, shift):
pass
def onMouseMove(self, x, y, button, shift):
pass
def onMouseMoveMap(self, x, y, button, shift):
pass
def onDblClick(self):
pass
def onKeyDown(self, keycode, shift):
pass
def onKeyUp(self, keycode, shift):
pass
def deactivate(self):
pass
def onCircle(self, circle_geometry):
pass
def onLine(self, line_geometry):
global mid_point
array = arcpy.Array([arcpy.Point(line_geometry.firstPoint.X,line_geometry.firstPoint.Y),arcpy.Point(line_geometry.lastPoint.X,line_geometry.lastPoint.Y)])
polyline = arcpy.Polyline(array)
edit.startEditing()
edit.startOperation()
cursor = arcpy.da.InsertCursor("CrossLine", ["SHAPE@"])
cursor.insertRow([polyline])
del cursor
mid_point = arcpy.Point()
mid_point.X= line_geometry.positionAlongLine(0.50,True).firstPoint.X
mid_point.Y= line_geometry.positionAlongLine(0.50,True).firstPoint.Y
edit.stopOperation()
edit.stopEditing(True) ## Stop the edit session with True to save the changes
arcpy.RefreshActiveView()
obj = Edit_Operations()
pass
def onRectangle(self, rectangle_geometry):
pass<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Hi ,
could you help me
I need to snap the line feature after line drawn , also need to activate the Edit tool programmatically to select the annotation .
requirement steps:
step 1 : create a line feature with snapping mode activation
step 2 : select the annotation
step 3 : snap the selected text to the mid point of the created line feature.
Intention of the code :
created 3 classes in addin
one for line feature draw
two for select the annotation
three for button click if necessary
created a gdb (D:\Sample.gdb)
created annotation and line feature classes for testing in arcmap using the addin tool.
Gopi
