<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags" creationComplete="onCreationComplete(event)"> <s:layout> <s:VerticalLayout gap="10" paddingBottom="20" paddingLeft="20" paddingRight="20" paddingTop="20"/> </s:layout> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.events.PanEvent; import com.esri.ags.geometry.Polyline; import com.esri.ags.symbols.SimpleMarkerSymbol; import com.esri.ags.tasks.supportClasses.DensifyParameters; import mx.events.FlexEvent; import mx.rpc.AsyncResponder; import mx.rpc.Fault; private var points:Array = new Array(); private var moveObj:Graphic; private var moveIndex:int; private var timer:Timer; protected function onCreationComplete(event:FlexEvent):void { initMovingGraphic(); createTrackPoints(); initTimer(); } private function initMovingGraphic():void { moveObj = new Graphic(new MapPoint(-13629302.512116898, 4545949.1442212695, map.spatialReference)) moveObj.symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 9); trackLayer.add(moveObj); } private function initTimer():void { timer = new Timer(20); timer.addEventListener(TimerEvent.TIMER, onTimerTick); } private function createTrackPoints():void { var densifyParams:DensifyParameters = new DensifyParameters(); densifyParams.geometries = [trackLine]; densifyParams.maxSegmentLength = 5; geometryService.densify(densifyParams, new AsyncResponder(onDensifyResult, onDensifyFault)); } protected function onDensifyResult(result:Array, token:Object = null):void { points = new Array(); var resultLine:Polyline = result[0]; for each(var pt:MapPoint in resultLine.paths[0] ) { points.push(pt); } } protected function onDensifyFault(fault:Fault, token:Object = null):void { trace("densify faults " + fault.faultString + " " + fault.message.toString()); } protected function onMoveClick(event:MouseEvent):void { timer.stop(); moveIndex = 0; timer.start(); } protected function onTimerTick(event:TimerEvent):void { moveObj.geometry = points[moveIndex]; moveIndex++; } protected function onPauseResumeClick(event:MouseEvent):void { if (timer.running) { timer.stop(); btnPauseResume.label = "Resume"; } else { timer.start(); btnPauseResume.label = "Pause"; } } private var mustResumeTracking:Boolean = false; protected function onMapPanStart(event:PanEvent):void { if (timer.running) { timer.stop(); mustResumeTracking = true; } } protected function onMapPanEnd(event:PanEvent):void { if (mustResumeTracking) { timer.start(); mustResumeTracking = false; } } ]]> </fx:Script> <fx:Declarations> <esri:Extent id="initialExtent" xmin="-13635000" ymin="4541000" xmax="-13625000" ymax="4547000"> <esri:SpatialReference wkid="102100"/> </esri:Extent> <esri:GeometryService id="geometryService" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer" /> </fx:Declarations> <esri:Map id="map" extent="{initialExtent}" panStart="onMapPanStart(event)" panEnd="onMapPanEnd(event)"> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/> <esri:GraphicsLayer> <esri:Graphic> <esri:geometry> <esri:Polyline id="trackLine" spatialReference="{new SpatialReference(102100)}"> <fx:Array> <fx:Array> <esri:MapPoint x="-13629302.512116898" y="4545949.1442212695"/> <esri:MapPoint x="-13628433.040920155" y="4546016.026621019"/> <esri:MapPoint x="-13628327.940006264" y="4544449.067541175"/> <esri:MapPoint x="-13626541.2244701" y="4544582.832340674"/> <esri:MapPoint x="-13626665.434641063" y="4546379.102505373"/> </fx:Array> </fx:Array> </esri:Polyline> </esri:geometry> <esri:symbol> <esri:SimpleLineSymbol width="3" color="0xFF0000"/> </esri:symbol> </esri:Graphic> </esri:GraphicsLayer> <esri:GraphicsLayer id="trackLayer" /> </esri:Map> <s:HGroup gap="20" width="100%"> <s:Button label="Move" click="onMoveClick(event)"/> <s:Button id="btnPauseResume" label="Pause" click="onPauseResumeClick(event)"/> </s:HGroup> </s:Application>
*Can I modify the speed, I mean with tweens I can set the time for the animation, that control the speed, I got that I can change the maxSegmentLenght, but I didn't get how it works.
*what exactly the use of the "Densify" parameters and method.
This operation densifies geometries by plotting points between existing vertices.
How it is work?What is "Densify"?Where is FLEX API reference?
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags" creationComplete="initial();"> <s:layout> <s:VerticalLayout gap="10" paddingBottom="20" paddingLeft="20" paddingRight="20" paddingTop="20"/> </s:layout> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.events.MapMouseEvent; import com.esri.ags.geometry.Polyline; import com.esri.ags.symbols.PictureMarkerSymbol; import com.esri.ags.symbols.SimpleMarkerSymbol; import com.esri.ags.symbols.Symbol; private var _polyline:Polyline; private var _points:Array = new Array(); private var movObj:Graphic; var movIdx:Number = 0; var onMov:Boolean = false; protected function initial():void { pictureMarker.height=20; pictureMarker.width=40; movObj = new Graphic(new MapPoint(-13629302.512116898, 4545949.1442212695, new SpatialReference(102100))) movObj.symbol = new SimpleMarkerSymbol("circle",9); trkLyr.add(movObj); } protected function onMoveClick(event:MouseEvent):void { movIdx = 0; for each(var pnt:MapPoint in trackLine.paths[0] ) { pnt.spatialReference = map.spatialReference; var p:Point = map.toScreen(pnt); _points.push(p); } animation.target = movObj; playBack(); } protected function playBack():void { if(movIdx < _points.length-1) onMov=true; else { onMov=false; movIdx = 0; _points = new Array(); } if(onMov) { setSegmentPath(_points[movIdx].x,_points[movIdx].y,_points[movIdx+1].x,_points[movIdx+1].y); animation.play(); } } protected function setSegmentPath(xstart:Number, ystart:Number, xend:Number, yend:Number):void { sX.valueFrom = xstart; sY.valueFrom = ystart; sX.valueTo = xend; sY.valueTo = yend; animation.motionPaths.pop(); animation.motionPaths.push(sX,sY); } protected function reDraw():void { //Somthing I should do here } protected function goOn():void { movIdx++; playBack(); } ]]> </fx:Script> <fx:Declarations> <s:Animate id="animation" repeatCount="1" duration="5000" effectEnd="goOn()"> <s:SimpleMotionPath id="sX" property="x" /> <s:SimpleMotionPath id="sY" property="y" /> </s:Animate> <esri:Extent id="initialExtent" xmin="-13635000" ymin="4541000" xmax="-13625000" ymax="4547000"> <esri:SpatialReference wkid="102100"/> </esri:Extent> <esri:SimpleLineSymbol id="sls" width="6" color="0xFF00FF"/> </fx:Declarations> <!--mapMouseDown="onMapClick(event)"--> <esri:Map id="map" extent="{initialExtent}"> <!--extentChange="reDraw()"--> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/> <esri:GraphicsLayer id="gLayer" > <esri:Graphic id="track"> <esri:geometry> <esri:Polyline id="trackLine" spatialReference="{new SpatialReference(102100)}"> <fx:Array> <fx:Array> <esri:MapPoint x="-13629302.512116898" y="4545949.1442212695"/> <esri:MapPoint x="-13628433.040920155" y="4546016.026621019"/> <esri:MapPoint x="-13628327.940006264" y="4544449.067541175"/> <esri:MapPoint x="-13626541.2244701" y="4544582.832340674"/> <esri:MapPoint x="-13626665.434641063" y="4546379.102505373"/> </fx:Array> </fx:Array> </esri:Polyline> </esri:geometry> <esri:symbol> <esri:SimpleLineSymbol width="3" color="0xFF0000"/> </esri:symbol> </esri:Graphic> </esri:GraphicsLayer> <esri:GraphicsLayer id="trkLyr" > </esri:GraphicsLayer> </esri:Map> <s:Button label="Move" click="onMoveClick(event)"/> </s:Application>
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags"> <s:layout> <s:VerticalLayout gap="10" paddingBottom="20" paddingLeft="20" paddingRight="20" paddingTop="20"/> </s:layout> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.events.MapMouseEvent; import com.esri.ags.geometry.MapPoint; import com.esri.ags.geometry.Polyline; import mx.collections.ArrayCollection; import spark.filters.GlowFilter; private var _polyline:Polyline; private var _points:Array = new Array(); private var _isPolyline:Boolean = true; protected function onMapClick(event:MapMouseEvent):void { if (event) { _points.push(event.mapPoint); } if (_isPolyline) // if checkbox selected { if (!_polyline) { _polyline = new Polyline(); _polyline.spatialReference = map.spatialReference; } if (_points.length > 1) { _polyline.paths = [ _points ]; animationFilter.stop(); gLayer.clear(); var gr:Graphic = new Graphic(_polyline, sls); gLayer.add(gr); animationFilter.target = gr; animationFilter.play(); } } else { animationFilter.stop(); gLayer.clear(); for each (var pt:MapPoint in _points) { var graphic:Graphic = new Graphic(pt, sms); gLayer.add(graphic); } animationFilter.targets = ArrayCollection(gLayer.graphicProvider).toArray(); animationFilter.play(); } } protected function onClearClick(event:MouseEvent):void { animationFilter.stop(); gLayer.clear(); _polyline = null; _points = new Array(); } protected function onSelectionChange(event:Event):void { _isPolyline = box.selected; onMapClick(null); } ]]> </fx:Script> <fx:Declarations> <s:AnimateFilter id="animationFilter" repeatCount="0" duration="500" repeatBehavior="reverse" bitmapFilter="{new spark.filters.GlowFilter()}"> <s:SimpleMotionPath property="color" valueFrom="0x00FF00" valueTo="0x0000FF"/> <s:SimpleMotionPath property="blurX" valueFrom="6" valueTo="18"/> <s:SimpleMotionPath property="blurY" valueFrom="6" valueTo="18"/> </s:AnimateFilter> <esri:Extent id="initialExtent" xmin="-13635000" ymin="4541000" xmax="-13625000" ymax="4547000"> <esri:SpatialReference wkid="102100"/> </esri:Extent> <esri:SimpleLineSymbol id="sls" width="3" color="0xFF0000"/> <esri:SimpleMarkerSymbol id="sms" color="0xFF0000" /> </fx:Declarations> <s:CheckBox id="box" label="Line / Point" selected="true" change="onSelectionChange(event)" /> <esri:Map id="map" extent="{initialExtent}" mapMouseDown="onMapClick(event)"> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/> <esri:GraphicsLayer id="gLayer" /> </esri:Map> <s:Button label="Clear" click="onClearClick(event)"/> </s:Application>
