I agree that is incredibly helpful for folks to post their final code. Thanks for that. I do have a question about line-38. Dont you want "lyr.definitionQuery = query # set the layers defintionQuery " to be outside of the 'else'? You want to set the def query to the variable 'query' either way, and NOT just in the case of the else, right? I cant say for sure, because I am elementary with my python.
Thank you very much for the Clean Code and comments as someone new to Python and Arcmap this really helps me understand whats going on. Thanks again I appreciate it.
Thanks for sharing this. It is just what I was looking for.
#DDP: Set Definition Query on a secondary index #Variables that need to be set by user: #mxdpath = r'C:\Users\Test.mxd' # string #outputfolder = 'PDFFolder' # string #namefield = 'THE FIELD CONTAINING THE NAME OF THE RESULTING PDF FILE' #string #queryfield = 'THE FIELD CONTAINING THE VALUE FOR THE DESIRED QUERY' #string #layers = ['LIST','OF','LAYERS'] # list ('Layer1_UpdateQuery', 'Layer2_UpdateQuery', 'etc') #Import Modules import arcpy, os # Set Variables mxdpath = r'D:\arcgis\Samples\DDP_Index2.mxd' # string outputfolder = 'D:\PDF' # string namefield = 'FIPS' # string queryfield = 'STATE_NAME' # string layers = ['CountySel_FIPS'] # list mxd = arcpy.mapping.MapDocument(mxdpath) # Start Loop through Data Driven Pages for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1): mxd.dataDrivenPages.currentPageID = pageNum # set the current page pageName = mxd.dataDrivenPages.pageRow.getValue(namefield) # get the pageName pageName += '.pdf' # add '.pdf' extension for file name pdf = os.path.join(outputfolder, pageName) # add pageName to output folder to get full output path # Start Loop through all layers of mxd file for lyr in arcpy.mapping.ListLayers(mxd): # for every layer in mxd's Layer List if lyr.name in layers: # if layer name in user input list above #value = mxd.DataDrivenPages.pageRow.getValue(queryfield) # get value of query field value = mxd.dataDrivenPages.pageRow.getValue(queryfield) print value if lyr.definitionQuery == True: # if a definitionQuery Exsts... query = lyr.definitionQuery + "AND" + queryfield + "=" + "\"" + value + "\"" # Add new to old else: query = queryfield + "=" + "\"" + value + "\"" # else create a new query lyr.definitionQuery = query # set the layers defintionQuery else: print 'Next' # else print next, this isn't necassary, but its a good place holder print pageName arcpy.mapping.ExportToPDF(mxd, pdf) # export the current Page to pdf del mxd, lyr, pageName, pageNum, query, value
for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1): mxd.dataDrivenPages.currentPageID = pageNum pageName = mxd.dataDrivenPages.pageRow.STATE_NAME for lyr in arcpy.mapping.ListLayers(mxd): if lyr.name == maskLayer: lyr.definitionQuery = '"STATE_NAME" <> %s' % pageName arcpy.RefreshActiveView() arcpy.mapping.ExportToPDF(mxd, os.path.dirname(outputFolder)+ os.sep + pageName + ".pdf") lyr.definitionQuery = ""
import arcpy, sys, os arcpy.OverWriteOutput = 1 mxd = arcpy.mapping.MapDocument("CURRENT") print "Enter save as pdf location:" pdfDir = arcpy.GetParameterAsText(0) outputFolder = pdfDir + r"\PDFs" df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] maskLayer = arcpy.mapping.ListLayers(mxd, "state_bnd110", df)[0] maskField = "STATE_NAME" for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1): mxd.dataDrivenPages.currentPageID = pageNum pageName = mxd.dataDrivenPages.pageRow.STATE_NAME for lyr in arcpy.mapping.ListLayers(mxd): if lyr.name == maskLayer: lyr.definitionQuery = '"STATE_NAME" <> pageName' arcpy.mapping.ExportToPDF(mxd, os.path.dirname(outputFolder)+ os.sep + pageName + ".pdf") lyr.definitionQuery = "" arcpy.RefreshActiveView() del mxd arcpy.GetMessages()
