With the recent release of ArcGIS Pro and better labeling and symbolizing ribbons instead of mulitple windows, cartographic production will be increasing. Labeling is still one of those task that we all spend a lot of time working on though. Merging the possiblities of dynamic labeling to get most labels placed and then converting to annotations to clean up and add other labels is the only solution right now to create labels that are more cartographically apealling. My idea is to make it possible to dynamically/auto label using the MapPlex option and then have the ability to manually adjust then lock text that I am happy with the placement of. This would reduce data management and allow faster map production. I could easily see this being possible with the new threading capability of the ArcGIS Pro application but would also like to see ArcMap be optimized to be able to draw and label faster with this new labeling technique.
The solution to this in both ArcMap and ArcGIS Pro is to convert the labels to annotation - either in a database or in a map as graphics.
Convert labels to annotation
https://pro.arcgis.com/en/pro-app/latest/help/mapping/text/converting-labels-to-annotation.htm
In order to maintain a link to the base features you will need to convert to feature-linked annotation.
-Wendy
@WendyHarrison I highly disagree that this is already offered. I have one label I need to move. Creating annotation is overkill. Also, annotation demands that I pick a scale. Labels scale dynamically when I zoom in and out. So I have to lose functionality to move one label. How about when you create labels - a check box that says, I don't want any of your placement options, I want to place the labels myself. @KoryKramer you're always super helpful - have you run across this idea anywhere? Thank you.
A good place to start when working with text is the Add text on a map topic. Part way down is a chart that will take you through different tasks and how to do them with labels, graphic text on a map and geodatabase annotation.
If you’re not interested in the overhead of geodatabase annotation you can convert your labels to graphic text and then edit as needed. To have the text elements scale like labels you will need to remove the reference scale from the graphics layer.
Convert labels to annotation main topic
Convert labels to graphics tool topic
To just create a handful of text by pulling the strings from features you can use a graphics layer and the auto text tool. To then not label those features use an sql query on the label class to prevent those features from labeling
@WendyHarrison I'm with Andrea on this one. What you're putting forward are workarounds or just alternate ways of putting text on a map, not a way of manually moving one label, which is what the thread was about.
Of what you offered, graphics layer/auto text is the most promising, but it appears to be bugged: centering the text caused it to disappear. It's also a workaround for this issue, not a way to move a label.
Labels are dynamically placed by the label engine. Geodatabase annotation and graphic text are static and can be edited.
If text is needing to be edited it will need to be geodatabase annotation or graphic text.
What is the issue with this one label? Maybe we need to back up and look at the problem label and then come at it from there.
for your additional issue - "centering the text caused it to disappear" - can you provide more info?
@WendyHarrison Thank you for the links and the info. Converting labels to graphics is probably what I was looking for and would probably work. I also like the info on the auto text tool and then sql querying out the labels that are in the graphics layer.
I still support the idea of manually moving labels, however, with no conversion.
I agree that converting the labels to graphics or annotation is not a work around for me. I have several labels and only a few of them need to be moved. Converting all of the labels restricts the flexibility I have with modifying that map afterwards.
I would like to ability to select individual labels and move them manually to another location.
Thank you all (in the meantime) for offering up work-arounds! I have been exporting the maps into PowerPoint or Adobe Illustrator to add slick text boxes as labels.
Yes. Annotation/graphics are way too cumbersome in practice. There should just be some sort of manual override for positioning individual labels without converting.
Understanding that annotation layers are cumbersome for certain situations, I will say that they are very useful for our application of labels. If no one has mentioned it before, if the biggest issue is that as you change the data/attributes, the labels in an annotation layers doesn't update, try looking at "feature linked" annotation. I'm not overly familiar with it but I know other folks who have used it successfully. This is only intended as a suggested work around, not a complete solution to your problem. Hope it helps!
@RoseF right, there are many limitations with feature-linked that prevent me from using them, namely, that they have to live in the same location as the data. I don't want to put annotation layers in our data library nor do I want to make redundant copies of our data for each project. Also, the options for adjusting the formatting of annotation are strewn all over the UI; it's way too difficult and clunky to make updates to be worth it.
@wayfaringrob I completely understand. We don't have the same issues you do with annotation layers but I can see why they are not an adequate solution for your team. Fingers crossed Esri will be able to make some improvements to the auto labeling!
It would be really cool if you could somehow build in the ability to select auto labels and manually move them so the software could place most but you could just move the couple that aren't quite working while keeping them as auto-labels.
1,000% agree
Also agree. Another user requested the same and the solutions offered are always to convert to annotations: https://community.esri.com/t5/arcgis-pro-ideas/move-the-labels-in-a-manual-way/idi-p/974473/page/2#comments
But I very frequently find that I have 30 odd labels in a view but only one or two not well placed so it would make much better sense to have the function, either in the ribbon or right-click style, to manually move one or two to improve readability or aesthetics, rather than waiting for the annotation tool to work.
This one is a couple years old, but when I went to enter my suggestion, this popped up.
I agree. Sometimes there's just one or two problematic labels that you really need to be in a certain spot... rather than having to build a separate SQL query and custom rules for them, or converting all your labels to annotations or graphics, it would be nice if you could just click on the one label and say "OK, for this one, just put it here."
This has been brought up before by others but I'd like to throw my two cents in as the advice that always comes back is "Just turn them into annotations". Fiddling with labels is easily the most time consuming part of my job. It's frankly wild that there isn't a manual mode for this, it seems incredibly basic. I update the attribute tables for my work frequently and so I need them to not be graphic elements. The label weighting system is extremely temperamental. For the regulator I work with they require the labels to not overlap any features as well as not have any label leader lines cross. I'll have wide open swathes of space in my layout and allow a huge maximum offset and for some reason there will always be one label that wants to be on top of a feature. A manual option that still connects the labels to the attribute table would be the single best quality of life change for my workflow.
Sign in to post, follow content, and more. New here? Register for free.
