The ability to Pause Labeling with Maplex is awesome. Sometimes I forget to turn the labels back on before I print a map. A warning prompt asking if you're sure you want to print the map without labels would be wickedly useful.Thanks
Lisa
When exporting or printing a map, have the option to turn on a warning message box that will tell you if your labeling is paused or not. There are many times where I pause the labeling while I perform corrections on a map, only to export/print the map and have forgotten that I paused the labels. A simple warning that you can check on or off that would tell you that your labels are paused before the map is actually exported/printed would be nice.
Closing this ArcMap idea as ArcMap is being retired.
Sign in to post, follow content, and more. New here? Register for free.
