It would be a much simpler workflow to do it from the attribute table instead of having to go to the item details or use the export data analysis tool (which uses credits). Our users want easy access to the results of their anlaysis and being able to export easily is important.
Yes...having this functionality in the Map Viewer, is a "no brainer" . I can not understand why this functionality has only been added to Web App. The Map Viewer is by default the standard way the majority of users access the web maps. I can't tell you the number of times we've been asked by users if our data can be exported.
We've worked on a "data portal" for a couple of our projects and we have a Adaptation menu that is implemented via a dashboard. Basically folks select a number items to tell the tool what enviroment they are working in and the tool suggests adaptation actions they can implement. We've been asked multiple times if we can generate a report from this information so it can be used in things like grant applications. Short of telling them to do a screen grab, I'm not sure how to do this. It would be a super helpful function to have.
Sign in to post, follow content, and more. New here? Register for free.
