Once a feature has been removed from the ToC, all locks on that data should be removed as close to instant as possible.
This problem plagues those who use Excel spreadsheets in ArcGIS Desktop especially.
Scenario:
You've added your spreadsheet into ArcGIS Deskstop ready to map x and y, you then spot a problem and need to make a change to the spreadsheet. Currently you must remove the spreadsheet and close down the .mxd that the spreadsheet was added to or you'll find your data is locked.
This can also happen to Shapefiles and/or Feature classes.
Removing the burden on the user to sort these locks out would simplify, quicken, and overall improve his/her experience.
I know this is a long standing issue, so apologies if this is a duplicate idea but could not find a similar one.
Best Regards
Peter Kohler
p.s. imo, The line "Its Microsoft’s fault" doesn't cut it anymore as it doesn't mean anything to your novice GIS user - they just wont use it again.
