Yes Please!
Being able to import fields and domains is great. However, manually adding field aliases, and the choice lists for all of the domains seems like a solvable problem that would save everyone so much time!
@DanielO_Donnell1 's recommendation is perfect.
Using the Alter Fields (multiple) tool allows users to pass any number of class / field_name / alias combinations programmatically into ArcGIS Pro using a little bit of Python.
For more information on the Alter Fields (multiple) tool check out the documentation linked below.
https://pro.arcgis.com/en/pro-app/3.4/tool-reference/data-management/alter-fields.htmIn the example below a stand alone table with columns 'field_name' and 'field_alias' is used to update the alias of each named field in a given class.
import arcpy target_class = << path to target >> alias_table = << path to alias table >> field_updates = [] with arcpy.da.SearchCursor(alias_table, ['field_name', 'field_alias']) as cursor: for row in cursor: name, alias = row field_updates.append([name, "", alias]) arcpy.management.AlterFields( target_class, field_updates )
Sign in to post, follow content, and more. New here? Register for free.
