Hey Vijayashree,By callout do you mean pop-up boxes? If so then this video can help you! http://video.arcgis.com/watch/1695/configuring-effective-pop_dash_up-windowsTo edit your Legend, click on content, then click the dropdown box button (the little box with a triangle in it) next to your feature and choose rename. This will let you edit what it will say in your legend.Hope this helps!Tim
Thanks Tim my question was not renaming the legend. If anybody look at the map , the legend shows simply a red dot. Instead I want to show the users to know what that red dot means say for example PM locations or Facilities or some meaninng full name like that. I will watch the video and see what best I can do with pop ups. Call out what I meant was click on the map something like that when somebody hovers on the map. Hope this clarifies. Thanks once again
Before you upload your data the first time add a field named, SYMBOL and for each point you have chose a name you would like it to show for this feature. For example for each feature that is a facility type "Facility" in the SYMBOL field. Now upload that layer. Once uploaded, go to "Change Symbols" for that layer. Under "Use:" choose "Unique Symbols" and as "To show:" choose your "SYMBOL" attribute field. Now you can assign a Symbol for each attribute and it will also have a meaningful name. Click "Done Changing Symbols"Let me know how that looks!
With an ArcGIS online organizational account you are able to create buffers in ArcGIS Online.
