Consume large credits in terms of what % of organisation allocation or a discrete number?
I just came across another area where ESRI is not at all clear on credit usage: premium maps/data. Take a look at the information page for the US Crime Statistics map, for example. The item's brief description warns that an AGOL subscription is required, but says nothing about credit usage. Without any prior knowledge of what premium content is, one might assume (as I did) that the Premium tag simply referred to that need for a subscription and nothing more.
There are exactly two warnings on this page about credits: one in a mouse-over popup on the Premium tag (very easy to miss), and another in very, very small font way at the bottom of the description. Incidentally, the hyperlink embedded in the latter does not actually take you to any description of credit usage--it just makes you log in again (even if you already were), and then drops you back at your organizational account page. Super helpful.
Reading through this breakdown of credit usage, it's not immediately clear how a map like this uses credits. My best guess is the line that reads "Demographics and Map Layers: 10 credits per 1,000 map requests (pan, zoom, and identify)" in which case, yikes, just exploring a map like that for more than a few minutes can really start to eat into your credit budget, especially if you don't have a whole lot to start out with.
Perhaps a pop-up warning when you click "Open Map" that explains not just the fact that you'll be using credits, but how those credits will be used up is in order. At the very least, maybe a big bold warning in the item's brief description. Because otherwise, it really does feel like ESRI is intentionally obfuscating credit usage in an effort to trick users into spending more credits than they realize.
At the December 2021 ArcGIS Online update, when publishing layers from My Content that involve geocoding a source file such as a CSV, credit estimates are now provided and you will not be able to publish the layer if you do not have enough credits.
Sign in to post, follow content, and more. New here? Register for free.
