Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Home
ArcGIS Pro
ArcGIS Pro Ideas
Export symbology with feature class
JasonKennedy
Can we please have the ability to export symbology with a feature class / Layer when exporting it to a geodatabase. The process of reassigning symbology can be ultra time consuming.
I had to export feature classes from an SDE to a file geodatabase so that i could publish the features as a service (I will submit one on this as well). I had to go in and reassign symbology for each layer after the export. In some cases I was not able to find the exact symbology so I had to create new. It would be a great feature to just let me/us export it with the data.
Find more posts tagged with
Geodatabase
Already Offered
Status: Already Offered
Comments
IngmarAlbinson
Why
implement
functionality
that already exist?
Feature Class is saved in a database, symbology is saved in mxd.
Export your sde data to a file database, use
Set Data Source(s)
in ArcCatalog on your mxd and you can easy have exactly the same symbology to file database.
John_S
Or you could always use the map or layer package functionality as, well, that is pretty much exactly what that functionality was designed to do.
http://resources.arcgis.com/en/help/main/10.1/index.html#//00s500000013000000
Plus, there are some other tools in that same toolset in ArcToolbox that would similarly help with that and/or similar types of situations. Hope that helps.
Join the Conversation
Sign in to post, follow content, and more. New here? Register for free.
Register
Quick Links
Recent Posts
User Groups
Followed Content
Community Help
