Filtering features in a feature class or filtering rows in a table using a definition query is only possible when data is added to a map. The definition query is a property of the map layer, and is not available as a property of the feature class or table. For example, when you open the Properties dialog box for a feature class or a table, there is no option available to define a definition query.
This is true for both ArcCatalog and ArcGIS Pro. When you preview data in either ArcCatalog or in a Catalog view in ArcGIS Pro, you can preview the data directly as a precursor to using the data for analysis or visualizing the data in a map to know you will be working with the correct dataset. The place to define properties of a map or table layer is in the map itself, in both ArcMap and in ArcGIS Pro.
In ArcGIS Pro, after adding data to a map you can add a definition query as described in this help topic: https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/definition-query.htm. If your data is stored in a database, you may also be interested in defining a query layer: https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/creating-a-query-layer.htm.
Sign in to post, follow content, and more. New here? Register for free.
