Error: Chargement de l'image impossible: http://10.1.0.100/ArcGIS/rest/services/Map_dynamic/MapServer/export?dpi=96&transparent=true&format=png8&bbox=382398.38085919805,150171.12439732553,382872.5151407999,150407.13320267646&bboxSR=null&imageSR=null&size=896,446&f=image
http://10.1.0.100/ArcGIS/rest/services/Map_dynamic/MapServer/export?dpi=96&transparent=true&format=png8&bbox=382398.38085919805,150171.12439732553,382872.5151407999,150407.13320267646&bboxSR={"wkt":"PROJCS[\"NTF_Lambert_Zone_II\",GEOGCS[\"GCS_NTF\",DATUM[\"D_NTF\",SPHEROID[\"Clarke_1880_IGN\",6378249.2,293.46602]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]],PROJECTION[\"Lambert_Conformal_Conic\"],PARAMETER[\"False_Easting\",600000.0],PARAMETER[\"False_Northing\",200000.0],PARAMETER[\"Central_Meridian\",2.3372291667],PARAMETER[\"Standard_Parallel_1\",45.8989188889],PARAMETER[\"Standard_Parallel_2\",47.6960144444],PARAMETER[\"Scale_Factor\",1.0],PARAMETER[\"Latitude_Of_Origin\",46.8],UNIT[\"Meter\",1.0]]"}&imageSR={"wkt":"PROJCS[\"NTF_Lambert_Zone_II\",GEOGCS[\"GCS_NTF\",DATUM[\"D_NTF\",SPHEROID[\"Clarke_1880_IGN\",6378249.2,293.46602]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]],PROJECTION[\"Lambert_Conformal_Conic\"],PARAMETER[\"False_Easting\",600000.0],PARAMETER[\"False_Northing\",200000.0],PARAMETER[\"Central_Meridian\",2.3372291667],PARAMETER[\"Standard_Parallel_1\",45.8989188889],PARAMETER[\"Standard_Parallel_2\",47.6960144444],PARAMETER[\"Scale_Factor\",1.0],PARAMETER[\"Latitude_Of_Origin\",46.8],UNIT[\"Meter\",1.0]]"}&size=896,446&f=image
What do you you see if you do this: console.log(r.geometry.spatialReference); Does that spatial ref match your map's?
this.sr = new esri.SpatialReference({ "wkt":'PROJCS["NTF_Lambert_Zone_II",GEOGCS["GCS_NTF",DATUM["D_NTF",SPHEROID["Clarke_1880_IGN",6378249.2,293.46602]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",600000.0],PARAMETER["False_Northing",200000.0],PARAMETER["Central_Meridian",2.3372291667],PARAMETER["Standard_Parallel_1",45.8989188889],PARAMETER["Standard_Parallel_2",47.6960144444],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",46.8],UNIT["Meter",1.0]]' });
zoom_query: function(layerName, fieldName, id, scale, outFields){ var query = new esri.tasks.Query(); if (typeof(id) == 'string') id = "'"+id+"'"; query.where = fieldName+" = "+id; query.returnGeometry = true; if (outFields !== undefined){ query.outFields = outFields; } var thisref = this; var l = this.mm.getLayerByName(layerName); if (l == null){ alert("zoom_query->Layer "+layerName+" don't exist"); return; } l.queryFeatures( query, function(featureSet){ var r = featureSet.features[0]; if (thisref.apv.type == 'Point'){ var zoomLevel = thisref.mm.map.setLevel(thisref.mm.getScaleLevel(thisref.apv.scale)); thisref.mm.map.centerAndZoom(r.geometry, zoomLevel); } thisref.mm.showInfoWindow(r); }, onError ); } }
I don't if it is because I use a spatial reference which doesn't have a wkid or anything else...
