I work for local goverment in a rural setting. The majority of our land is farm ground. I was wondering if it woudl be possible to switch a label class based on an area that is defined in a map (or based off of a polygon).
Example:
If i am zoom into an area that comprises of mostly farm ground, then the label class (that i set up) would automatically choose "Ag land".
If i moved to a municipal area, then it would automatically switch to the "Municiple" Lable Class.
Location enabled as opposed to only controlled by attribute.
