Hi Ken,
This is an old post but perhaps this will be helpful. This is aimed at the idea of having multiple copies of a table in the same map document. If you run the Make Table View tool from within a modelbuilder session and choose 'Add to display', a table view should be added to the table of contents. The table remains in the map document even after saving / closing / re-opening. I tested this with version 10.2.2, ArcSDE and SQL Server 2008 R2.
Merry Christmas,
Paul Lohr
Closing this as it was submitted against ArcMap. If I understand the ideas correctly, this is possible in ArcGIS Pro. The same table can be added to a map multiple times and each table view can have different definition queries applied. Moreover, a single table view can have multiple definition queries applied and you can toggle between them as with any other layer in ArcGIS Pro.
Sign in to post, follow content, and more. New here? Register for free.
