I've noticed that ctrl-z doesn't clear / undo text when editing domains in ArcGIS Pro - maybe across the board. Would be handy!
Paul
Hi Paul - I'm looking at the ArcMap shortcut keys for editing and vertices (see images below) and they're identical - even with the factory default of CTRL-Z. I'm wondering if the CTRL-Z shortcut key got reassigned by local users in the ArcMap days to delete vertices? As it is, it does make sense that a CTRL-Z (which in an undo) would undo the edit. If you use the D key and click a vertex, it deletes a single vertex. If you hold down the D key, you can delete a group of vertices using a lasso.ArcGIS Pro CTRL+ZArcMap CTRL+ZArcGIS Pro Vertices shortcutsArcMap Vertices shortcut
Sign in to post, follow content, and more. New here? Register for free.
