Yep, same problem here. It is remarkable that this functionality is not available out of the box. I have hundreds, sometimes thousands, of features that I need to relate to a row in an aspatial table, but I have to do the same edit operation one at a time for each feature. Esri has put so much work into the implementation of relationship classes, and yet we don't have the tools to efficiently edit them. Please post some information on here if a solution is found.
John.
I had a look and I can't find a geoprocessing too or anything that will do this. You can select a contiguous set of lines (route), then ctrl-click buttons in the feature attributes box to get to (and select) the related class field for all of them, but then you can't assign a value en bloc to the selection.
As originally posted, you must literally right-click then 'Add Selected' for Each. And. Every. Feature. One. At. A. Time.
Esri's work flow for this process is not efficient. This is fine for two or three items, but in our business datasets, this could be hundreds or even thousands of features.
This idea has been closed as a duplicate of the Data Management Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
https://community.esri.com/t5/data-management-ideas/relationships-relate-multiple-features-to-single/idi-p/923060
Sign in to post, follow content, and more. New here? Register for free.
