First of all I want to know why is there not a good description about the algorithm that is used to determine the clipping of a raster based on a polygon. When you look at the slope you can find a very good description about the used methode. This would be very welcome to be use in reports where you have to describe the used methode when analysing data.
A second thing is that it would be helpful if you can choice which part (%) will be used to determine the clipping routine. For example I think the tool now use 50% of the cell to decide if the cell will be extracted or not. When you can choice a percentage it would be possible to get a fully filled polygon with data instead of cells with nodata values.
