Add the ability to set a different map scale at the subtype/attribute level (just like symbology), not just the layer level. This would significantly reduce the number of layers required in a map document – no more adding the same layer 6 times, each with a different definition query and map scale range.
Add a choice to <General> tab, under “Scale Range” for “Show Scale Range by Symbology” (similar in concept to the <Label> tab “Scale Range”.
The <Symbology> tab is likely place for this, since you already distinguish subtype/attributes to set different symbols, simply add the “Out Beyond” and “In Beyond” levels along with them.
