Hi Susan (et al),
Thanks for submitting and voting for this idea. I realize it's an old one, so I am adding some information about how the interactive profile graph works in ArcGIS Pro, to see if this meets your needs.
The interactive profile graph creates an in-scene graphic line - either from a newly digitized line, or by copying the geometry from an existing line feature. Editing that (graphic) line will update the profile graph... but... it does NOT maintain a reference to the feature it was initially pulled from.
We don't maintain the link because there are many possible edits that could be done to the original source line (eg: add vertices, delete vertices, split feature, delete feature, etc), so rather than tracking all the possible changes that can happen, the recommended workflow is to keep the feature-you-want-the-profile-graph-built-from as SELECTED, and then click the 'Apply' button (as-needed) to update it, per the 19-sec mark of the above video.
Can this workflow work for your needs? It's an extra click (to reload the elevation profile again), but it gives you full control as to WHEN the graph updates.
Thanks, Nathan.
Sign in to post, follow content, and more. New here? Register for free.
