Unable access customize Stylx file by using SymbolStyle API in Java.
SymbolStyle symbolstyle = await SymbolStyle.OpenAsync(String Path); (.Net).
But in java not find the Open Method of SymbolStyle API.
Hi Shiva,
you may use the DictionarySymbolStyle class (DictionarySymbolStyle| arcgis-java) to achieve the same results. In using that class ensure you have the right specification type in the constructor.
I put the below code snippet together for illustration.
private void loadSymbolStyle(String PATH_TO_SYMBOL, String PATH_TO_A_SHAPEFILE) { List<String> keys = new ArrayList<>(); keys.add("key1"); keys.add("key2"); ShapefileFeatureTable shapefile = new ShapefileFeatureTable(PATH_TO_A_SHAPEFILE); FeatureLayer featureLayer = new FeatureLayer(shapefile); featureLayer.loadAsync();
DictionarySymbolStyle dictionarySymStyle = new DictionarySymbolStyle("mil2525d", PATH_TO_SYMBOL); dictionarySymStyle.loadAsync(); dictionarySymStyle.addDoneLoadingListener(() -> { if (dictionarySymStyle.getLoadStatus() == LoadStatus.LOADED) { System.out.println("Loaded!!!"); symbolFuture = dictionarySymStyle.getSymbolAsync(keys); try { Symbol symbol = symbolFuture.get(); featureLayer.setRenderer(new SimpleRenderer(symbol)); mapView.getMap().getOperationalLayers().add(featureLayer); //add loaded layer to map mapView.setViewpointGeometryAsync(featureLayer.getFullExtent(), 100); //zoom to extent
} catch (InterruptedException | ExecutionException inEx) { System.out.println("Get Exception: " + inEx.getMessage()); } } else { System.out.println("Load Error: " + dictionarySymStyle.getLoadError().getAdditionalMessage()); //use this for debugging your code } });
