It would be great to see some kind of workflow that would allow us to scan a PIT tag and auto-populate a Survey123/Collector field. As described in this geonet post: https://geonet.esri.com/thread/184426-survey123-populate-field-based-on-input-port.
This widget works with BioMark scanners and is 3/4 of what we need. It can connect to a scanner via BlueTooth and scan a PIT tag but does not auto populate a field in Survey123.
InfraMarker RFIDs - Overview (arcgis.com)
If it could be converted to a S123 add-in and auto populate a field on a form (maybe with a standard field name like "PIT code") it would solve a huge need in the wildlife community and increase the use of S123 by biologists. I have biologists that would rather record data on paper, if they could store the PIT id in S123 they would convert to using S123! The PIT id is a 16 digit string and is prone to errors when typed in.
Berntsen International’s InfraMarker® solution seamlessly integrates Biomark RFID readers with the Survey123 application. RFID scans can be initiated directly from the Survey123 app, and the scanned PIT tag data is automatically returned to the application—including within repeat records.
For more information, please contact us at info@inframarker.com.
Watch a quick walkthrough of how InfraMarker works with Biomark readers: https://youtu.be/ykFN-BBSbUA
Ready to purchase an InfraMarker license for Biomark? Visit:InfraMarker License for Biomark
Sign in to post, follow content, and more. New here? Register for free.
