Microsoft SQL Server database requirements for ArcGIS 10.2.x, support currently only extends to Microsoft SQL Server 2014.
http://resources.arcgis.com/en/help/system-requirements/10.2/index.html#//015100000070000000
Can this be extended for Microsoft SQL Server 2016 ?
We in Scottish Water are using ArcGIS Desktop 10.2.1 as that has been proposed as the most stable utility version from ESRI. Scottish Water Management intend to use the latest updates from Microsoft and hence want to use the SQL Server 2016 version in their estate. But unfortunately that is not supported with ArcGIS Desktop 10.2.1. How can we get rid of this ?
On ArcGIS 10.4 Microsoft SQL Server database requirements for ArcGIS 10.4.x—Help | ArcGIS Desktop there is a note:
**Microsoft SQL Server 2016 is supported at ArcGIS 10.4 and 10.4.1. The Microsoft ODBC Driver 13 for SQL Server is only supported by ArcGIS 10.4.1 clients. For connections from ArcGIS 10.4 clients, the Microsoft ODBC Driver 11 must be used.
but I quess that does not extend back to ArcGIS 10.2.1 as there is:
Microsoft SQL Server 2014 is supported at ArcGIS 10.2.1 and 10.2.2.
So it seems that the connection code has changed a lot between ArcGIS 10.2 and 10.4 versions.
(By the way, just noticed that Microsoft ODBC Driver 11 for SQL Server is not supported(can't install) on Windows Server 2016)
This idea was closed as ArcGIS Desktop is no longer in development.If a similar enhancement is requested for the current software, please feel free to open a new idea relating to ArcGIS Pro.
Sign in to post, follow content, and more. New here? Register for free.
