System: Vista, ArcGIS 9.3Hello, I wrote a python code to AddJoin a grid shapefile (File A) to a bird range shapefile (File
.They have a field in common (GID).However, the error message is ERROR 000732: Input Features: Dataset H:/temp_D/testt does not exist or is not supportedFailed to execute (MakeFeatureLayer).Please kindly advise how to modify the code.Thank you.(The file location is "H:/temp_D/testt/grid.shp""H:/temp_D/test/birdrange.shp")#Import standard library modules import arcgisscripting import os #Create the Geoprocessor object gp = arcgisscripting.create(9.3) #Get a list of the featureclasses in the input folder source_fc = "H:/temp_D/testt" Entity = "H:/temp_D/test" outputfolder = "H:/temp_D" gp.Toolbox = "Data Management" # convert a featureclass to a layer gp.MakeFeatureLayer_management (source_fc, "source_lyr") # have Layers for AddJoin gp.AddJoin_management("source_lyr", "GID", Entity, "GID", "KEEP_ALL") # convert a layer to a featureclass gp.CopyFeatures_management ("source_lyr", source_fc) gp.FeatureClassToShapefile_conversion(source_fc, outputfolder) # clear memory of layers gp.Delete("source_lyr") gp.AddMessage(gp.GetMessages()) print gp.GetMessages()
