Hello All,
I apologize if this question has been asked a dozen times. I have done a ton of research, but I feel like I am still in the rabbit hole. I am trying to create a Map Book using ArcGIS Pro and python. My goal is to iterate through my index layer, zoom to selection, export that selection to a PDF, and then append all those individual maps to a PDF.
The way I am tackling this issue is to create GRID first, which is the code below:
#Part 1: Create Grid
#Import System Modulesimport arcpyfrom arcpy import env#Set environment settingsarcpy.env.workspace = "C:\data\"
#Set local variablesoutputFC = "Map Index"inputFC "Sanborn_1920_AllBldgs"polygonWidth = "139.2 meters"polygonHeight = "153.7 meters"numberRows = "3"numberColumns = "5"startingPageNum = "5"
#Execute GridIndex Featuresarcpy.cartography.GRIDIndexFeatures(outputFC, inputFC, "INTERSECTFEATURE", "NO_USEPAGEUNIT", None, polyonWidth, polygonHeight, "", "", 3, 5, 7, "NO_LABELFROMORIGIN")
My next step is to loop through my table of contents, zoom to each selection, and make it its own map, and that is where I get confused. Does it make sense to use def zoom_export or arcpy.mapping module?
