HiI'm cyclying through the results of a find task with a line like this for (j in results[dijit.byId('layerselect').get('value')].feature.attributes) {To get the field names so my datagrid can be built dynamically from the results, regardless of layer the find is run against.Sometimes this works, when it does, the attributes of each found record look like thisattributes: ObjectCHARGE_DESC: Array[1]
DATE_REGISTERED: Array[1]
INT_ID: Array[1]
OBJECTID: Array[1]
REFERENCE: Array[1]
REGISTER_ID_VERSION: Array[1]
REGISTER_PART: Array[1]
SHAPE: Array[1]
_0: 0
_RI: true
_S: a
xyz: Array[1]
With the field values stored as arrays.When it fails, usually when only one thing is found it looks like this
attributes: Object
DATE_REGISTERED: "20/11/1984"
INT_ID: "191702"
OBJECTID: "7137"
REFERENCE: "S215N/002/SIDM"
REGISTER_ID_VERSION: "1"
REGISTER_PART: "3B"
SHAPE: "Polygon"
xyz: "9"
__proto__: Object
With the field attributes just as text strings. my code then breaks with TypeError
arguments: Array[2]
get message: function () { [native code] }
get stack: function () { [native code] }
set message: function () { [native code] }
set stack: function () { [native code] }
type: "non_object_property_load"
__proto__: Error
Any ideas? Or even an easier way to return all the field names of a found record?CheersACM
