I am using SQL server 2012 SP1 and created the SQL Query Layer and once I open it in ArcMap 10.3.1 then I find few feature disappeared at the bottom. Also, I do pan the map to the bottom and do refresh the map ,features get disappeared. I search the same issue in Google and find out the below URL :
http://desktop.arcgis.com/en/arcmap/10.3/manage-data/gdbs-in-sql-server/sqlserver-spatial-types-and-arcgis.htm#ESRI_SECTION1_AE69A93272D34B3B835BE38D4E36FEA8
Is it the same issue with SQL Server 2012 also.
Is any map frame defined for query layer in which data can not be displayed beyond that.
Your help would be highly appreciated.
