Wondering if there is a way to make the extent remain the same, even if the index layer extent varies. I'd like to do an atlas with one page for each bus route that intersects a study area. So, the index layer is based on the bus routes (each feature is equal to the envelope defined by a given route) For each page of the atlas I want the extent to remain unchanged (showing entire study area). Then I can use the "page definition query" settings to query the bus routes layer such that the corresponding bus route is shown on the map. One solution is to create an index grid with a bunch of stacked polygons each equal to the same extent and populate an attribute with the route numbers. If I have to I'll do this, but I thought I would check if there is a better way. I believe this would be a nice enhancement. You could easily do atlases that compare multiple themes of data for the same area or temporal maps of the same area, etc...
This is very easy. And there are 2 simple ways to accomplish this.First determine the extent or scale you want to use.Create your data driven pages. Set you DDP in the Definition Tab. then select the Extent Tab.In the extent tab select Center and Maintain Current Scale. so whatever you set your scale to before you start to export the DDP it will make maps centered on the polygon or point feature all at the same scale.Method 2 is less fraught with possibilities for error. Below the Center and Maintain Current Scale selection is a choice for Data Driven Scale.First create an attribute for your DDP feature with the scale at which you wish to generate your pages. This attribute will have to be a number attribute (double or Long Integer) .You can put in a scale for your index layer as well that will be different. so if you want 1:24,000 enter 24000 in the scale attribute.Now when you export your pages they will all be at the scale value you enter into the scale attribute.
A little late to the party, but here all the same. The solution is to have two data frames.The DF that has the data drive pages will be 'off screen' and DF that has the static extent will be on screen.Screen shot attached.[ATTACH=CONFIG]28340[/ATTACH]
Data Driven Pages were not designed for this purpose. I personally would not use DDP and would script it using arcpy.mapping but your solution to create stacked index polygons for each route should work. It is very difficult to manage overlapping polygons.With arcpy.mapping you can simply iterate through each layer and set the definition query and then ExportToPDF before setting the next query.Jeff
try: import arcpy, sys, traceback print "Working..." mxdPath = r"Z:\GISpublic\GerryG\WaterResources\WaterSampleSiteAutoMap\WaterSampleSiteAutoMap22.mxd" mxd = arcpy.mapping.MapDocument(mxdPath) df = arcpy.mapping.ListDataFrames(mxd)[0] lyr = arcpy.mapping.ListLayers(mxd, "WaterSampleSiteMaster", df)[0] print lyr.dataSource theAttribute = "SiteID" #GetAListOfEachAttribute listOfAttributes = [] print "Start cursor" rows = arcpy.SearchCursor(lyr.dataSource) for row in rows: listOfAttributes.append(row.getValue(theAttribute)) for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT"): if elm.name == 'gbglabeler': elm = elm break for item in listOfAttributes: GBGquery = '"SiteID" =' + '\''+ item + '\'' print "Working on: ",item print GBGquery lyr.definitionQuery = GBGquery elm.text = "Site: " + item outputjpg = "Z:\GISpublic\GerryG\WaterResources\WaterSampleSiteAutoMap\SiteMaps\\" + item + ".jpg" arcpy.RefreshActiveView() arcpy.mapping.ExportToJPEG (mxd, outputjpg) print "done" except arcpy.ExecuteError: msgs = arcpy.GetMessages(2) arcpy.AddError(msgs) #If the error is with the script, or with python, find error and report it to the screen... except: tb = sys.exc_info()[2] tbinfo = traceback.format_tb(tb)[0] pymsg = "PYTHON ERRORS:\nTraceback info:\n" + tbinfo + "\nError Info:\n" + str(sys.exc_info()[1]) msgs = "ArcPy ERRORS:\n" + arcpy.GetMessages(2) + "\n" arcpy.AddError(pymsg) arcpy.AddError(msgs)
I too would like to be able to maintain the same extent for DDP. All that is needed is to add an additional option on the "Extent" tab which says "Keep current extent".
I found a simple way to achieve DDP where the extent of the maps remains exactly the same:
*If you don't have an ArcGIS Advanced Licence:
You, my friend, are a genius.
