It's that time again to do a little roll up of which Desktop ideas have seen status changes since the last update, https://community.esri.com/community/gis/applications/arcgis-pro/blog/2017/06/27/arcgis-desktop-ideas-on-the-move-june-2017?sr=search&searchId=a87b08b0-f00b-444e-a87d-a1a37175ea89&searchIndex=0.
4 Desktop ideas have been moved to Under Consideration:
ArcGIS Pro GPS Toolbar
Batch processing in ArcGIS Pro
Create an option for ArcGIS Online administrators to limit the length of time an ArcGIS Pro license can be checked offline by users.
Select by Location in ArcGIS Pro
14 Desktop ideas have been moved to In Product Plan:
Copy Parallel tool in PRO
Disable "Authorize ArcGIS Pro to work offline"
New Geodatabase Tool in Folders in ArcGIS Pro
Give us back the basic ability to create folders within dialog!
ArcGIS Pro - Copy Path
Remove warning when changing Subtype in ArcGIS Pro
Set symbol color from RGB values in attribute table
Undo field calculations in ArcPro
Map Service Enhancements on ArcGIS Pro
Summarize by Median
Python Scripting for Exporting Map Series in ArcGIS Pro
Add full COGO functionality to ArcGIS Pro
AutoCAD 2018
Split Polygon and Construct Polygons tools for ArcGIS Pro
As always, I hope that sharing these updates is insightful. I wanted to thank you for participating in the process and let you know that we’re listening!
