Hello everyone,
I have been tasked with deploying the Mo23rt.exe file with the following command line switches /JKNOR
We are deploying this on Windows 7 and above 32 and 64 bit clients
I'm currently using MDT and a application package to call the exe with the proper parameters.
However when it gets to this particular application the WISE installer progress bar gets to 98% says something about "skipping cartographic fonts" and it shows C:\Windows\Fonts\esri_9,ttf
and just stops
doesn't fail doesn't continue
As odd as it sounds if i click back and forth between the mdt calling task sequence window and the locked up install eventually it will "wake up and continue" otherwise i've left it run over night and come back to the same 98% progress bar
