BTW, there's no setup for 10.3 because VS 2013 doesn't come with an out-of-the-box setup project. I'm dropping support for this app anyway, and will not create a version for 10.4. I strongly recommend migrating to ArcGIS Runtime. Collector and AppStudio are also viable approaches for non-programmers.
Thank you for the quick reply,
I have it on both. I went ahead and ran the installer from 10.2, then
created the apps folder as it is listed in the reg file, restarted the
machine and it started working. Thank you!!
You need to make sure it’s also installed on the ArcReader machine. See the FAQ for other tips.
--Mark
Hey partner, I have 10.3, but the 10.3 version i downloaded does not have a setup file. Therefore I ran the regedit file, then ran the add addin. I can get the gps layer to show in ARCmap but it does not show when I open the published file from said map. Not sure what I am doing wrong. Did I miss something?
Thank you
