So I just started with a Pro add-in and have added a DockPane. The user fills in input and I send that to a geoprocessing function. In the DockPane I have a button with a click event
Private Sub btnGo_Click(sender As Object, e As RoutedEventArgs) Handles btnGo.Click
Try
'collect WPF form info
DoGp(info)
Catch ex As Exception
MessageBox.Show(ex.Message, "Exception", MessageBoxButton.OK, MessageBoxImage.Error)
End Try
End Sub
In a separate module I have
Public Async Sub DoGp(ByVal vg As Info)
Try
Dim toolPath As String = "management.CreateFishnet"
Dim progDlg As ProgressDialog = New ProgressDialog("Running Geoprocessing Tool", "Cancel", 100, True)
progDlg.Show()
Dim progSrc As CancelableProgressorSource = New CancelableProgressorSource(progDlg)
Dim res As IGPResult = Await Geoprocessing.ExecuteToolAsync(toolPath, params, envr, progSrc.Progressor, GPExecuteToolFlags.Default)
progDlg.Hide()
If res.IsFailed Then Throw New Exception("Geoprocessing tool failed.")
Debug.Print(ex.ToString)
Throw 'crashes here
End Try
End Sub
When I run it and there is an error in the output there is an unhandled exception at the line Throw:
An exception of type 'System.Exception' occurred in MyAddin.dll but was not handled in user code
I have Try-Catch in the calling code and also in the module so why is it not propagated?
