I am trying to disable the M & Z values in either the 'geotagged photos to points' or 'spatial join' geoprocessing tools within Model Builder. I know you can do this outside the Model in your workspace but the environment setting is not available in the tool's dialogue box within the Model. In the model you can however right click the tool>properties and see the Environments tab which does have M & Z value to manipulate but there is no option to disable, only to select resolution, tolerance and that the output has the value.
The ultimate goal is to be able to use the 'delete identical' or 'integrate' tools with the new point feature.
