I have a print template that will not return the value of one field. All other fields work. I have two nearly identical surveys where the templates work. I have tried my report template in those surveys and it works, I have tried those report templates in this survey and they do not work. I would say it is something wrong with the field, however the field works perfectly in AGOL, ArcMap and Pro.
Survey data is here
http://survey123.arcgis.com/surveys/ff5dd475f0a8497192e1e54736dd4a55/data
Estate data is populated
Estate information doesn't flow through to the example
Estate information doesn't flow through to the report template
any idea why this would happen?
