I have a form already published and contains data. The operation manager decided to add a repeating table to the published on which contains a geopoint. When you try to add repeating to the exisiting form all previous data will be deleted. is there anyway to create the new geopoint table and then make relationship with the main form. so in that way when you go back to add repeating table to the form you will not loose the old data.
