I do not know if this is the right place as I am used to the old forum and can not find anything in this new design.
I have a question: How to display range values instead of labels (Std. Deviation Classification)?
Thank you very much,
Martin
Hi Martin,
You can edit the label. Select/highlight < 1,6 Std. Dev. Delete it and replace it with 30,574700 - 34,632885. After you click OK on the Layer Properties dialog, you should see the change in the ArcMap TOC. If you have generated a Legend, you should see the change there as well.
Regards,
Dan
Hi Dan,
thank you very much. I know that it is possible manually. But my idea was that one could somehow define specific labels showing the values instead the StdDev. I am now using layers as templates. However, still have to change the labels manually which takes a lot of time.
Do you perhaps know how I could create/chnange the label script?
Thank you and best regards
