From Eclipse I run C:\Program Files\ArcGIS\Pro\bin\Python\Scripts\propy.bat provided by the Installation of ArcGIS Pro.
the following python script:
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">import</SPAN> sys
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>sys<SPAN class="punctuation token">.</SPAN>executable<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>sys<SPAN class="punctuation token">.</SPAN>version<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> p <SPAN class="keyword token">in</SPAN> sys<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>p<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> k<SPAN class="punctuation token">,</SPAN> v <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetInstallInfo<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>items<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN>k<SPAN class="punctuation token">,</SPAN> v<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">from</SPAN> argis<SPAN class="punctuation token">.</SPAN>gis <SPAN class="keyword token">import</SPAN> GIS <SPAN class="comment token"># @UnresolvedImport</SPAN>
g <SPAN class="operator token">=</SPAN> GIS<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
g<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
generates the following Output:
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python.exe
3.5.3 |Continuum Analytics, Inc.| (default, Feb 22 2017, 21:28:42) [MSC v.1900 64 bit (AMD64)]
Q:\_EclipseWorkspaces\b.e\Geoprocessing_py3\src\test
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\DLLs
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages
C:\Program Files\ArcGIS\Pro\Resources\ArcPy
C:\Program Files\ArcGIS\Pro\Resources\ArcToolbox\Scripts
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\future-0.16.0-py3.5.egg
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\pytz-2017.2-py3.5.egg
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\setuptools-27.2.0-py3.5.egg
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\sympy-1.0-py3.5.egg
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python35.zip
Installer xyz.xyz
InstallType N/A
BuildNumber 8933
InstallDate 18.09.2017
SourceDir Y:\ESRI\ArcGIS_10.5.1\ArcGIS-Pro_2.0\ArcGISPro\
Version 2.0
SPNumber N/A
InstallDir c:\program files\arcgis\pro\
InstallTime 16:27:40
SPBuild N/A
ProductName ArcGISPro
File "Q:\_EclipseWorkspaces\b.e\Geoprocessing_py3\src\test\test.py", line 19, in <module>
from argis.gis import GIS # @UnresolvedImport
ImportError: No module named 'argis'
I would like to know if this behaviour is by design or do expecting something impossible?
How do I proceed to use the ArcGIS Python API in "classic"-Geoprocessing?
