Needing to download a csv item from AGOL. I have called the item.download function, and it appears to work, placing the zip folder at
'/tmp/Runway21.zip'. Where is this and how do i access it? Here is the present code:
Hi Ian deNeeve, Ian deNeeve
you can try doing
import tempfile
print tempfile.gettempdir()
ALTERNATIVELY if you are unsure why not specify the save_path
Then you will know exactly where it is.
download(save_path=None, file_name=None)https://developers.arcgis.com/python/api-reference/arcgis.gis.toc.html#arcgis.gis.Item.download
download
Downloads the data to the specified folder or a temporary folder if a folder is not provided.
Argument
Description
save_path
Optional string. Folder location to download the file to.
file_name
Optional string. The name of the file.
Yes. Figured out how to specify a path. I was trying various approaches and having no luck. Once i took it from the Online Notebooks environment to specifically Jupyter, as launched from my machine, I was able to specify a path and it works.
Thanks, Victor.
Ever figure out how to run it online in a jupyter notebook? I'm having the exact same issue.
