On the following page ProConcepts Map Authoring · Esri/arcgis-pro-sdk Wiki · GitHub is stated that the Map object has a map scale property, but I cannot find this property. MapView.Active doesn't have a map scale property neither.
So how can I get and set the map scale?
Hello Matthew,
thank you for your reply! For the map view, setting the map scale works as follows:
MapView mapView <SPAN class="operator token">=</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">;</SPAN> Camera camera <SPAN class="operator token">=</SPAN> mapView<SPAN class="punctuation token">.</SPAN>Camera<SPAN class="punctuation token">;</SPAN> camera<SPAN class="punctuation token">.</SPAN>Scale <SPAN class="operator token">=</SPAN> <SPAN class="number token">5000</SPAN><SPAN class="punctuation token">;</SPAN> mapView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ZoomToAsync</SPAN><SPAN class="punctuation token">(</SPAN>camera<SPAN class="punctuation token">,</SPAN> TimeSpan<SPAN class="punctuation token">.</SPAN>Zero<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Barbara
This is exactly what I am looking for, kudos to @BarbaraSchneider2
Camera camera <SPAN class="operator token">=</SPAN> newMapframe<SPAN class="punctuation token">.</SPAN>Camera<SPAN class="punctuation token">;</SPAN> camera<SPAN class="punctuation token">.</SPAN>X <SPAN class="operator token">=</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">118.465</SPAN><SPAN class="punctuation token">;</SPAN> camera<SPAN class="punctuation token">.</SPAN>Y <SPAN class="operator token">=</SPAN> <SPAN class="number token">33.988</SPAN><SPAN class="punctuation token">;</SPAN> camera<SPAN class="punctuation token">.</SPAN>Scale <SPAN class="operator token">=</SPAN> <SPAN class="number token">30000</SPAN><SPAN class="punctuation token">;</SPAN> newMapframe<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SetCamera</SPAN><SPAN class="punctuation token">(</SPAN>camera<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Use the camera of the map frame. xy to center it, then scale it how you want. I should note this is for layouts. I don't know off the top of my head how it is done in the map view. Let me know if that is what you need and I can try and figure it out.
