I am logged into Survey123 for ArcGIS and I have gone into the Data section of my Survey.
I can generate a CSV of all the data in the survey, but I want to generate a CSV of the data between two dates only.
Does anyone know how to do this?
Hi John,
While in http://survey123.arcgis.com > Data, choose 'Open in ArcGIS Map Viewer' - here you can apply a filter to your data based on dates, and then use the tool Extract Data to extract your filtered data to CSV.
Carmel
Check the new updates to Survey123 for ArcGIS
https://community.esri.com/groups/survey123/blog
Enhancements to the Survey123 websiteAnalyze and Data tabs now include a date range filter to more easily create reports and understand submitted data. This filter option is quite handy if you want to better understand data captured. Your date filters will also be honored when you export your survey results in pdf format.
Check if it works for CSV as well.
Thanks for the reply Jayanta.
I see what you are talking about under the Analyze button.
But I want to save a copy of the Data under the Data button for specific dates.
Currently, the download cannot be filtered by the time slider. I've logged that as a possible enhancement.
Thanks James.
So if I want to download I have to download all the data and not just a selection of the data?
